Unigine Valley 1.0 Benchmark
Publisher: Unigine
Unigine's free Valley 1.0 benchmarking tool works well as a graphics benchmark as it is GPU limited and is thus incredibly taxing on the GPU whilst placing the CPU under very little stress.
Unigine's scoring system is effectively linear: a card with 2,000 points is considered twice as fast as one with 1,000 points, and half as fast as one with 4,000 points. As such, you can easily replicate and run the test on your own system to gauge roughly how big a difference an upgrade would likely make for you. Currently, Nvidia hardware tends to fare much better than AMD's in this test, so it is mostly useful for comparing AMD cards with other AMD cards and likewise with Nvidia.
Nvidia GeForce GTX 980 Ti 6GB
Nvidia GeForce GTX 980 4GB
AMD Radeon R9 Fury X 4GB
AMD Radeon R9 290X 4GB
2000
3000
4000
5000
6000
Score (higher is beter)
